I'm hoping someone can offer some advice on a new cooker I want fitting.
I want to replace my old cooker with a new one with induction hob. The new cooker/hob is rated at 13.9kW and the existing cable is 6mm from a 30a MCB. The length of the cable should only be about 3 meters (my fuse board is in one of the kitchen cupboards near the cooker).
I've had 2 electricians quote for the job but both had told me different things so I'm unsure which one to use.
1st electrician said the new cooker can be connected to the existing cable and it should be a fairly simple job.
2nd electrician has said that the cable needs changing to 10mm and a 40a MCB needs fitting (which is obviously gonna involve a bit more work removing the tiles & cupboards to fit the new cable).
Could anybody shed some light on which one I should use? I rather go for the quick and simple option and get the cooker in for Christmas as long as the cable already there is ok to use.
Thanks,
Thanks,
