Hi all. I have a 1970s house with a Ideal Mexico boiler on a vented system with a single heating zone. I am adding a single storey 40m2 extension and am just thinking about heating.
As im adding the new extension, this seems a good time to disregard the downstairs copper pipe in the floor (rather than wait for it to leak) and replace with a new run of 22mm speedfit to then branch off to rads. I will then create a second zone for this so I can control upstairs and downstairs seperatly.
My question is really about running the pipe. I am vaugely aware that pipe isnt supposed to be run in screed anymore, or it can but needs to be in some conduit. Is this correct? So the channels I dig for the pipe wold be quite hefty?
Alternativly the extension will be using a beam and block floor so could the 22 pipe be run under that in the void with some Armaflex around it?
How far can the 15mm take-offs be run from the 22mm pipe, could I run one up to 5 meters to a 2.5kw rad?
Lastly is it possible to run 10mm microbore pipe for the last section as it comes out of the floor/wall. I think this looks neater than having 15mm pipes.
Thanks for your help in advance
