I have a small area of wall that needs covering/cladding - I thought it would be ok done in lead but I'm a complete novice to lead.
In the photo below, it's the area from the top of the exposed section of beam down to the example rafter. It's about a 1m x 0.5m triangle.
Obviously there's a bit more brickwork to come out which will be replaced by some insulation and timber framework finished with plywood or cement board. Ideally I'd like the lead to lap onto the roof tiles and integrate with the conventional stepped flashing that will go further up.
Any thoughts on this would be greatly appreciated, in particular as I assume it's too big for a single piece of lead, how I would do it? I'm thinking 2 or 3 narrow strips nailed to the board and overlapped from the top?
Thanks.
Thanks.
