Hi everyone, I'm in the process of starting out with an extension to our property that will involve knocking through the rear wall, with the intent on creating a large open kitchen/diner/living area.
Architect is on with the plans now, and we'll be getting an SE in to calculate steel requirements and foundations to make sure it's done properly. However, something as important as my home, and as it's a structural change, I always want to understand what is being done, and more importantly why, before the experts get started. Just so I have at least some idea of what they're talking about.
The span when we knock through is going to be 6 metres, and with a large opening like this, isn't there a risk of the beam buckling? One other concern I have is that the house is quite high up in the pennines and is exposed at the back. I'd expect this will be taken into account, but to what extent will this impact any design?
I'm sure a bigger UB would help to prevent this, but as the blocks in the wall that will be supporting the beams are only 100 mm, doesn't that limit the size of UB we can spec? Or is it acceptable to have part of the flange 'overhanging' the block?
Alternatively, will the two beams (for inner and outer cavity wall) be connected together to offer additional strength against the buckling? If so, what is the best way to do this?
I know a lot of questions, but it'll really help me get my head around what's being done and, I hope, limit some of my anxiety.
Cheers
Cheers
