Thinner Shotgun Coax For Sky Q - Need Compression F Plugs
26 Mar 2010
Worcestershire
Hi all
Recently ran an extenstion cable for a friend and realised the cable provided was the thinner shotgun coax cable which as it turned out was fine as I was able to get some F plug connectors from Screwfix however I do prefer to use the compression F plugs that I have used for all my own coax installations.
Does anyone know where I can get some compression plugs for this thinner cable as I would like to go back and replace the screw on F plugs that Screwfix had in stock?
TIA
Ian
If it's just a small one-off job and you don't need bulk supplies then go to Ebay or Amazon.
Ebay, search: 5 x F Compression Plugs for WF65 Twin Satellite Shotgun Coax Cable by Cabelcon
Amazon, search: electrosmart Pack of 5 x Nickel F Plug Connector Compression/Snap & Seal for WF65 / CT65 Twin Coax Cable
If this or any other reply was helpful to you, then please do the decent thing and click the T-H-A-N-K-S button. It appears when you hover the mouse pointer near the Quote Multi-quote buttons. This is the proper way to show your thanks for the time and help someone gave you
Brilliant, thanks!
Found those on eBay but also found some others on Amazon aside from the ones you mentioned which gave me double the amount for the same cost
https://www.amazon.co.uk/dp/B01M9B0UR5/
Amazon - electrosmart Pack of 10 x Nickel F Plug Connector Compression/Snap & Seal for WF65 / CT65 Twin Coax Cable
Might help someone else out hence posting link.
