It’s strange that you’re seeing essentially the same thing on multiple circuits. Are the readings all very similar, as if you’re actually observing exactly the same fault, or do they differ a bit?
It would be odd for the sort of thing securespark describes to affect more than one or two.
I suggest you choose the simplest affected circuit (e.g. a cooker or shower) and disconnect at both ends, so you’ve just got the cable itself, and measure that.
Frankly I suspect you’ll look at it on Monday and you’ll have a “d’oh” moment as you spot an obvious mistake!!!
