Second thread of the day!!
I have often been puzzled regarding the earthing of my parents cottage.
It is supplied by an overhead supply from a transformer serving three properties (including my parents)
It is a very long overhead line and my parents home alone is supplied by six poles, the other two properties are right in the vicinity of the transformer.
In 1990 the cable drop from the pole to the house was installed to replace three separate cables from the pole to the house (a short length of these redundant cables are still inside the house in the wall). The incoming cable appears to be a split-con cable and on the left hand side of the cutout where the earth block would be is a plastic cover (it 'wobbles' a bit....I know you shouldn't, and was wondering if this might have been a cover that slides off, but that is not possible now due to the consumer unit been in the way)
When the cable was replaced there was an old 3036 board and the old cutout together with the meter was directly below it. When the new cable was installed, the cutout was put in it's present position and the earth cable from the 3036 board was left connected to nothing! (not long enough to be connected to earth on new cutout)-house not earthed for a few years!.
We had a new consumer unit installed some time later (16th edition 100mA Time Delay RCD and 30mA RCD) and an earth cable was installed to a rod.
My main question is though, is the earthing house meant to be TT or TN-S?
A few other things I had thought about include the overhead line is very long with the earth been thin, so although you won't know the impedance for sure without testing, in the case of a 30A 3036 fuse protecting a ring circuit, I have wondered how long would it actually take to disconnect in an earth fault?
I'm posting (or trying) to post some pictures to help.
Many Thanks
Many Thanks
