I removed the programmer and room thermostat and wired up receiver where programmer wasHive wall thermostats come as single and duel, in both cases it replaces the wall thermostat, but as single that is all it replaces, as duel it also replaces the programmer, I would assume the latter, so likely you have a wiring centre and likely you can remove the original thermostat at the wiring centre, however all we can do is guess, and that is not good enough.
Where the thermostat would connect will depend on what system you have, at moment no idea if combi or system single or duel gas or oil so can't answer.I removed the programmer and room thermostat and wired up receiver where programmer was
