Is this soil connector available??
8 Oct 2011
I am looking for a connector if available ?
I have a 110mm soil pipe entering my house from a new side extension toilet. This needs to be connected to a ground clay soil pipe. So the plastic needs to be bent down 90⁰ into the clay pipe which is currently flush with the concrete floor, I can nibble around the edge if needed but I would rather insert a male end into the clay due to the flow. The clay pipe is 95mm Internal, 130mm external.
Can anyone tell me if there is such a connection that would enable me to do this? Space is very tight so I dont have room to fit much.
Basically, I need some sort of flexible pipe with a 110mm to a clay, male end?
Or maybe a clay to plastic male then I could connect a flexible 110mm pipe?
Any advice or recommendations would be much appreciated!
I will try and post a pic.
Since my post I've been trawling the internet and maybe a flexible pan connector might work?
It has a 4" male end which could be pushed into the clay pipe and the female end can take the 110mm plastic.
In the bad old days this used to be done with a Multiquik - then rats would eat the soft plastic :eek:
I’ve replaced a few with multikwik fittings, I think because they leaked (not done one for years).
