    Dismiss Notice
Is this soil connector available??
Discussion in 'Plumbing and Central Heating' started by Jack07, 6 Feb 2020.
  1. Jack07
    Jack07
    8 Oct 2011
    90
    Thanks Received:
    Country:
    I am looking for a connector if available ?
    I have a 110mm soil pipe entering my house from a new side extension toilet. This needs to be connected to a ground clay soil pipe. So the plastic needs to be bent down 90⁰ into the clay pipe which is currently flush with the concrete floor, I can nibble around the edge if needed but I would rather insert a male end into the clay due to the flow. The clay pipe is 95mm Internal, 130mm external.
    Can anyone tell me if there is such a connection that would enable me to do this? Space is very tight so I dont have room to fit much.
    Basically, I need some sort of flexible pipe with a 110mm to a clay, male end?
    Or maybe a clay to plastic male then I could connect a flexible 110mm pipe?
    Any advice or recommendations would be much appreciated!
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    11,483
    Thanks Received:
    2,356
    Daventry
    Country:
    A photo would help
  4. Jack07
    Jack07
    8 Oct 2011
    90
    Thanks Received:
    Country:
    I will try and post a pic.
    Since my post I've been trawling the internet and maybe a flexible pan connector might work?
    It has a 4" male end which could be pushed into the clay pipe and the female end can take the 110mm plastic.
  5. Chris_W
    Chris_W
    26 Sep 2019
    2,914
    Thanks Received:
    786
    North
    Country:
    • Like Like x 2
    • Thanks Thanks x 1
  6. Nige F
    Nige F
    28 Jun 2005
    20,424
    Thanks Received:
    1,571
    Country:
    In the bad old days this used to be done with a Multiquik - then rats would eat the soft plastic :eek:
    • Like Like x 1
  7. Chris_W
    Chris_W
    26 Sep 2019
    2,914
    Thanks Received:
    786
    North
    Country:
    I’ve replaced a few with multikwik fittings, I think because they leaked (not done one for years).
  8. Sponsored Links
Loading...
Share This Page
