Hi looking for some advice just had a Alpha2 Auto Adapt replaced as developed an issue direct from Grundfos they sent me the latest Alpha 1 15-50/60 130 in its place ...i fitted it myself after turning the head so that the flow arrow matched my existing pump .Issue is its supposed to be whisper quiet yet its making a loud humming noise when set on 3 running around 28W if I turn it down to 2 it is slightly quieter and just about manages to heat the system...i have a 1 year old Worcester greenstar 24i boiler new port valves and all rads (9;single 4 doubles) had powerflush then i had 5 new rads... after the powerflush Ibhave balanced the rads and all heat up as they should the F&E tank in my loft had a drain down and was cleaned and fresh inhibitor added...my boiler is due its 1st service tomorrow having spoken to Grundfos they feel my pump may need to be upgraded as it may not be suitable for the rads i have hence the humming noise ... ive a convential new system boiler downstairs kitchen Hot water tank pump and port valves in upstairs airing cupboard ...F&E in loft above ...just cant understand why the pumps noisy...i know i put the pump on correctly as i had to turn it so the flow arrow matched the one I took off which points down towards the boiler or it a case that the system needs a bigger pump Grundfos have asked me to ask the engineer
What is the required flow rate? (required from the pump to satisfy the system)
What is the required head/pressure? (required from the pump) Any help appreciated
