- Joined
- 22 Apr 2018
- Messages
- 124
- Reaction score
- 3
- Country
Hi all,
we ordered some numbers of samples from different shops of engineered t+G oak floor.
All of the samples we received (bar one) have the ply substrate made out of thinner strips laid next to each other, as opposed to one unique piece of plywood.
On the other hand, when I look online at pictures of similar flooring, they all appear to be made with one unique plywood piece.
Is one solution better than the other? One of the merchants involved advised that they do do it with many contiguous strips next so that the glue can bond better.
Additional question: we are going to lay the T+G floor on top of OSB T+G.
Should we use the foam underlay or not?
I read some people that say you absolute don't use it on T+G but only clip on systems, others instead say it is better if you lay it.
Most notably, I read this discussion with much interest
https://www.diynot.com/diy/threads/solid-wood-flooring-appropriate-underlay.340038/
but not really one unchallenged take-home answer!
thanks!
thanks!
