Sorry bud and it isn't often I disagree with you but avoid the compact.If you struggling at all and really really really need to use a macerator, then get the sanicompact.
Bear in mind,some unfortunate soul will be digging around unblocking it at some point.We are installing a Saniflo macerator in the downstairs cliakroom but are struggling to choose a toilet that has room for it behind and still has the cistern flush to the rear wall. Any suggestions please.
Not if it is used properlyBear in mind,some unfortunate soul will be digging around unblocking it at some point.
I could have used that as my usernameBear in mind,some unfortunate soul will be digging around unblocking it at some point.
What's your reasoning? I was going to suggest a Sanicompact as well! Interested in hearing your far more experienced opinion, as on paper they look like a good ideaSorry bud and it isn't often I disagree with you but avoid the compact.
Look at the Sanislim or consider a baton of wood behind the cistern. There is the Turboflush but I don't like them either.
Have to remove pan to remove pump/motor box so takes longer to fix. Two components can give same symptoms and overly reliant on electronics in a nutshell.What's your reasoning? I was going to suggest a Sanicompact as well! Interested in hearing your far more experienced opinion, as on paper they look like a good idea
Thinking you mean the Sanipack, useful pump with side inlet.Yes- don't do it if you can possibly avoid it. If you really must then have a look at this one https://victoriaplum.com/product/th...pled-toilet-with-wooden-soft-close-seat-white- the dimensions say there's only 76mm behind the pipe outlet but it looks a lot more than that to me.
Or try the Pro-Up macerator- that's side entry rather than front.
EDIT Wrong forum- try Plumbing
ANOTHER EDIT Just checked my cheapo B & Q £38 toilet- that has 170 mm from where the adaptor collar ends up to the wall.
This. ^^ We have a Sanislim in our downstairs loo. Boxed it all in so very quiet too.Look at the Sanislim or consider a baton of wood behind the cistern
That's going to be a pain to fix when it goes wrong!This. ^^ We have a Sanislim in our downstairs loo. Boxed it all in so very quiet too.View attachment 184083
Nah. It went wrong after it had been in about 5 years - I chucked a wedge of Kleenex down it when I had a cold and it jammed up - didn’t notice until next morning when I heard a humming and buzzing. Toilet and cistern out in one go, lid off, pipes disconnected and with a little bit of a kerfuffle it was out. With the advice of Just Pumps on here, I replaced the capacitor and it was all good.That's going to be a pain to fix when it goes wrong!
