Afternoon ladies and gents.
I’m going to be building a workshop in the next month or so as my 30th birthday present and will create a build thread in due course on the ‘your project’ part of the site.
I have a question regarding the base. How thick do I need to go???
The workshop is going to be 12ft x 18ft built like so:
Concrete base 13ft x 19ft.
Concrete blocks 3 course high (maybe 6 high if I sit them on sides for added rigidity).
Timber structure then built on top of block.
Tin roof.
Ply lined.
8ft from floor to gutters. 14ft from floor to ridge.
The timber frame will be a 4” posts construction covered externally in Yorkshire boarding. And osb internally lined.
Roof will be pitched made up of mainly 4”x2” a-frames tied together. Again lined with osb.
Corrugated tin roof.
I don’t think it’s going to be that heavy compared to brick and it won’t have heavy/regular vehicular use. It’s just a place for the gardening equipment and tools and a work bench etc, (maybe a classic car restoration or two), so I thought I’d proceed like this:
Take the top soil off down to firm ground (I’m in a heavy clay area and the land is a bout a 1:10 incline)
Compact recycled crushed brick to a depth of 6” (calculated at 7ton online)
Soft sand binding layer (1ton)
1000GA DPM.
6” concrete slab. 5 ton of ballast to 1 ton of general purpose cement (40 25kg bags). Mixed with old diy mixer and trying get it done all in 1 go. I am also going to be adding 1kg of fibres to every ton of ballast to give a little added strength and flexibility.
My old man thinks I could get away with 4” of concrete. What do you guys recommend? Am I missing something? Should I go deeper? I don’t want to dig a strip foundation around the edge to keep cost down and I don’t fancy shelling out for any kind of rebar or mesh either.
Any input greatly appreciated.
Thanks in advance, Dom
Tin roof.
Ply lined.
1000GA DPM.
