Hi all,
Close to finishing off a kitchen remodel, and had some walnut worktops fitted (butted up to some quartz worktops).
To get the worktop nice up against a very uneven wall, the carpenter has taken out about 30mm to slide the 27mm worktop just under the wall.
The problem is, there is now a very uneven gap between the bottom of the wall and the worktop of between 1mm & 5mm, with some larger bits of plaster having flaked off during the cutting.
I've used filler to go down as far as I can without touching the surface of the wood, but it will be very difficult to neaten this edge (see picture below).
Q. Once I get to between 1mm & 2mm all the way round, and has been painted the wall colour, can i use a thin bead of brown caulk to hid the gap between the wood and the wall, or will this crack with worktop shrinkage...etc...?
What other options do I have to neaten this up?
Thanks in advance!
Thanks in advance!
