Any clever Excel users here?
26 Feb 2005
Gwynedd
Simple task: I have a spreadsheet for my golf scores. Along the top I have the par for the hole, then a row for each round. I wish to count the number of par scores on each round.
So I thought I could use COUNTIF(range, criteria) but the criteria only seems to allow me to compare to a specific value or one particular cell.
Ideas?
Can you calculate the difference between your score and the par. When the difference is 0, job done.
Nozzle
i'm reasonable good at excel and often answer questions on the excels forums, which maybe better place to go
say -
https://www.excelforum.com/
where you can easily load a sample
ANY way
COUNTIF should work
Assuming the PAR is in ROW 1 - and starts at B2 to S2 - although you may have a column for 1st half after 9 holes
{=SUM(N(headerange=columnname)*N(datarange>0))}
use control+shift+ enter to get the { brackets
if you Rows go up to row 10
And the PAR are in row 1
then
=SUM(N(B1:S1=B2:S10)*N(B2:S10>0))}
Dont need the N function
=SUM((B2:T2=B4:T20)*(B4:T20>0))
i'll try a sample sheet for you
Cant load a XL file, not sure if zip allowed
https://www.dropbox.com/s/a9r6vgoupjoh66p/GolfPar.xlsx?dl=0
say -
ANY way
COUNTIF should work
then
THANKS. I tried this but for some reason I get an error. I'll take some time later to take a look. I'm not clear on
a) the meaning of the curly brackets
b) what *(B4:T20>0) does
thanks
the curly brackets are to make it into an array formula - otherwise you get an error
only counting above a zero blank value
you need to
use control+shift+ enter when in the formula bar - that adds the { brackets
Ideas?
Following Nozzle's suggestion, do that , then use countif, with condition 0. That's assuming you want to count number of par scores, not par or lower.
