    Dismiss Notice
Any clever Excel users here?
Discussion in 'Software' started by WabbitPoo, 21 Mar 2020.
  1. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,710
    Thanks Received:
    138
    Gwynedd
    Country:
    Simple task: I have a spreadsheet for my golf scores. Along the top I have the par for the hole, then a row for each round. I wish to count the number of par scores on each round.
    So I thought I could use COUNTIF(range, criteria) but the criteria only seems to allow me to compare to a specific value or one particular cell.
    Ideas?
  2. Nozzle
    Nozzle
    23 Dec 2012
    2,053
    Thanks Received:
    259
    Suffolk
    Country:
    Can you calculate the difference between your score and the par. When the difference is 0, job done.
    Nozzle
  3. eta
    eta
    24 Apr 2008
    391
    Thanks Received:
    30
    West Sussex
    Country:
    i'm reasonable good at excel and often answer questions on the excels forums, which maybe better place to go
    say -
    https://www.excelforum.com/
    where you can easily load a sample
    ANY way
    COUNTIF should work
    Assuming the PAR is in ROW 1 - and starts at B2 to S2 - although you may have a column for 1st half after 9 holes
    {=SUM(N(headerange=columnname)*N(datarange>0))}
    use control+shift+ enter to get the { brackets
    if you Rows go up to row 10
    And the PAR are in row 1
    then
    =SUM(N(B1:S1=B2:S10)*N(B2:S10>0))}
    Dont need the N function
    =SUM((B2:T2=B4:T20)*(B4:T20>0))
    i'll try a sample sheet for you
    Cant load a XL file, not sure if zip allowed
    https://www.dropbox.com/s/a9r6vgoupjoh66p/GolfPar.xlsx?dl=0
    • Like Like x 1
  4. Mottie
    Mottie
    27 Feb 2017
    6,552
    Thanks Received:
    799
    Essexshire
    Country:
    Maybe it’s me but...
  5. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,710
    Thanks Received:
    138
    Gwynedd
    Country:
    THANKS. I tried this but for some reason I get an error. I'll take some time later to take a look. I'm not clear on
    a) the meaning of the curly brackets
    b) what *(B4:T20>0) does
    thanks
  6. Sponsored Links
  7. eta
    eta
    24 Apr 2008
    391
    Thanks Received:
    30
    West Sussex
    Country:
    the curly brackets are to make it into an array formula - otherwise you get an error
    only counting above a zero blank value
    you need to
    use control+shift+ enter when in the formula bar - that adds the { brackets
    • Thanks Thanks x 1
  8. fixitflav
    fixitflav
    20 Mar 2018
    691
    Thanks Received:
    57
    Stoke-on-Trent
    Country:
    Following Nozzle's suggestion, do that , then use countif, with condition 0. That's assuming you want to count number of par scores, not par or lower.
  9. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,710
    Thanks Received:
    138
    Gwynedd
    Country:
    got it working thanks
  10. eta
    eta
    24 Apr 2008
    391
    Thanks Received:
    30
    West Sussex
    Country:
    you are welcome
Loading...
Share This Page
