Good times ahead for some
24 May 2016
Mainly those with a jet washer as people block the drainage with kitchen roll and newspaper instead of using toilet paper
Its the wipes I suspect that are going to cause havoc, so many shops with the shelves cleared and/or limiting customers to numbers of packs that can be purchased. If half of them go down the toilet, then it's going to get busy I think.....
Agree with @Hugh Jaleak, wipes are a regular problem, given the panic buying, working from home and self isolation = more than a wipe/fatburg.
Two examples of what happens with wipes, blocked pump and chamber.... Chamber may only affect a few properties, I've seen pumps doing an entire village jammed up with wipes, and then the only solution to prevent a pollution is to tanker the incoming flow off site whilst someone has the task of stripping the pump down to unblock it.
That's our emergency fall back at work, when we're in trouble on an isolated site and there's either no bog, or there's a bog and no paper. :whistle:
deleted
Mod
