Bathroom Extractor Wiring
They are wrong. The fuse is to protect the cable not the fan.
Neither an isolator nor local fuse is required by the regs if it is on the lighting circuit.
Is it though? I'd need to check the blue book as I always treated it like a shower isolator where DP isolation is required.
My understanding of manufacturers instructions are that they should always be followed and that the mention of a 3A fuse is to reduce the likelihood of the fan catching fire if it seizes.
This may be the fan manufacturer covering their liability, but if I ignore the instructions then I become liable.
...but it's not - required by the blue book.
If that were the reason then it is not fit for purpose.
See: rest of (non-British) world.
To be fair to them I think it is just them stating what they think the regulations are.
How can that be if you fitted it according to BS7671 regulations?
I know of at least 3 other sparks who think it's required. One even reckoned on a story of a spark being taken to court for not fusing the fan and it catching fire.
I couldn't say if it's a true story, but we all know that fans regularly give up.
I completely agree that by conforming to BS7671 my ass 'should' be covered, but it's still good practice to comply with the instructions.
It doesn't matter what they think.
No appliances are required to have local isolation by BS7671.
I couldn't say if it is true either.
You may do it if you wish.
The instructions are guidance only and don't have to be followed, especially when they are wrong.
Here is a serious example of wrong manufacturers instructions.
This has been discussed before. I think you must “have regard to” the manufacturers instructions, but that doesn’t mean blindly following them if e.g. they are obviously wrong.
I had a bathroom fan where the instructions showed fuses in both the L and N supplies. I did not install it like that.
