Jammed JG Speedfit fitting
2 Dec 2013
Dear Experts,
Any advice about how to remove a jammed-on JG Speedfit fitting?
I’m unable to push the ring in at all; the fitting rotates on the pipe but doesn’t pull off.
Help!
Just fully unscrew the end (the ribbed part). Normally by hand, it will move. At worst, use suitable pliers.
With JG as above, it sometimes if you unscrew a little, it will then enable you to remove the fitting.
Hmm, I though unscrewing was to stop you pushing the end collar in, no?
I’ll have another fiddle and report back.
