Name of stone atop a pillar?
19 Feb 2015
What is the name commonly used for the concrete "stone" which sits on top of a pillar such as shown. I presume it's going to be something like top stone or cap stone? What do most builders refer to it as?
Thanks.
Pilaster cap in old money
A pilaster is traditionally a classical column which is built directly in, or against, a wall face - quite often flat rather than circular. So as this pier is free-standing, the capping cannot be described as a pilaster cap. 'Pier cap' is the more correct terminology.
OK then ... "A pier, in architecture, is an upright support for a structure or superstructure such as an arch or bridge"
Is the OP's pier supporting an arch or a bridge? If it is then it wont need a cap. :rolleyes:
I would also suggest that a pier is always attached to something, in this context a wall, but something closer to home like Blackpool pier is attached to the land. Whereas a pillar is independent.
So "pillar cap" it is then.
