- Joined
- 29 Mar 2020
- Messages
- 3
- Reaction score
- 0
- Country
Hi all,
Vent Axia Solo Plus HT (Model 427479) power but not working
I have a Vent Axia ceiling mounted extractor fan in an internal bathroom which has not been operating for the past few months. The unit is connected to the light switch and seems to be connected to the power as a blue LED light on the extractor fan turns on when the light switch is on. The fan itself, however, does not spin even when the LED is lit.
I have removed the cover and there are no obvious obstructions to the fan - it spins quite freely by hand. I have also reduced the Humidity screw adjuster to the lowest level (anti-clockwise) just in case it wasn't turning on due to any lack of humidity when I was testing. This made no difference. Does anyone know what might be causing the unit to be inoperable? Perhaps the motor is blown? Or the humidity detector frazzled? Is it something to do with the switch on the top right of the picture (does this switch check that the cover is on?)
I have found a replacement unit online for £80 or so which I am happy to purchase (https://www.ebay.co.uk/i/1507562685...a0IR76uCdHto3Wqj5trNy4h4Ki8e_vzMaArv6EALw_wcB). Will this be easy enough to fit without expertise?
Thanks for any tips and advice.
All the best,
Tom
All the best,
Tom
