Hi, Hoping I can get some help here. Drained down the system today by closing the valve on the F&E Tank outlet to plumb in some new rads.
When finished I opened the valve again but upon starting the boiler up and calling for HW on the primary circuit there became an increasingly violent banging/knocking from the boiler followed by a dry fan sound... at which point I switched HW demand off.
Ive tried this again later and although it took longer to get to the knocking it continued ... Now the boiler wont fire for the HW at all.
(The CH circuit works fine after bleeding the rads)
My question, though I understand from a previous question, there is an air pressure release valve but I suspect this isnt working? Am I correct in my assumption that the problem is an air lock and if so what is the process to bleed this ?
Many thanks
Many thanks
