I have a coat rack , ie a chunky-ish strip of wood about 24 inches long, 2 inches high and around 0.5 inches thick. It has four hooks on it. There are two metal vertical strips behind it a few inches from each end, each with a hole shaped like a circle with a smaller bit on the top ( kind of like an upside down keyhole), with the circle big enough for a width of a screw. So, if the screws were to be put into the wall( with a small gap), it's a simple matter of putting the two holes over the two screws.
It's hard to say how much it weighs with no coats - guessing 1 or 1.5 kg (I was trying to compare it to the weight of a bag of sugar)
Its a 30s terraced house, standard brick wall, guessing the wall thickness is one brick-length.
What kind of screws / rawl plugs etc should I get for this, and how should I go about doing this?
