My shower flow rate is terrible and regularly gets air locked. I'm thinking this is a combination of factors namely; 1. The hot water take off from the cylinder is from the vent pipe and well above the cylinder T. 2. The pipes go up into the loft via quite a few bends and are only just below the cold water tank. The pitch of the roof is quite low and the cold water tank is only just above the loft floor, so pressure isn't great.
Here is a diagram to illustrate the setup:
To improve flow rate to the shower, would it be better to change the hot water take off point to somewhere just above the cylinder using something like a surrey flange rather than high up on the vent pipe?
Would changing the cold water take off for the shower be better if it was taken off the cold water tank output, rather than the mains riser, to equal the pressure between the two?
Or would it be better to do both the above and fit a pump?
