Car port being domesticated: old bathroom window blocked up, front door removed/side light blocked up, hole for previous outside tap filled in, meters moved etc, new aerated blocks up the right side alsoOne other wall has new aerated inner leaf, two other walls have stud/50mm insulation/plasterboard. I'm happy with these but need advice on the wall where the redundant front door was.
1. Is this wall suitable for wet plastering (with expamet added over the interfaces between different elements). I mean, it's got a window/redundant meter voids blocked, a lintel etc? I was thinking of putting a skim bead on at DPC level to render/skim upwards from there
2. The three lower brick courses I was going to wire wheel clean and apply a couple of coats of Silka Rapid DPM, then bring a floor membrane up to skim bead/damp course. This would be lost behind the skirting.
Any thoughts?
Dain
