D
Deleted member 272719
Hello all
I had an electrician in the other day to quote for installing an extra light. There is a light at each end of the room and the middle tends to be a bit dark, so I want an extra light there. The house is 3 years old.
There is a 2 gang switch in the room, each gang operates one switch, and they both work fine. There are no ceiling roses and each lamp has twin and earth going to it. (I know that because I replaced one light fitting when I moved in, and checked the other after he'd gone due to his comments.
I would like another light with it's own switch, swapping the 2 gang for a 3 gang.
For various reasons I asked him if he could do it without taking up the floor upstairs. He said he could but he 'doesn't do plastering' so he'd put the plasterboard cut-out back in place and I'd have to have it skimmed myself. Fair enough, I don't mind that.
Anyway, he said he'd have a look in the switch and light fitting to 'check things out' and what he saw he obviously did not like. He made his excuses and left saying he'd have to check his diary and couldn't commit to the job at the moment.
Inside the switch there are 2 cables, each 3 core and earth - 2 brown, 1 blue. I must admin I haven't seen that wiring before, is it possibly because they haven't used junction boxes due to the floor being screwed and glued (taking a board up means it gets destructed in the process)?
Now he has me worried. Either there is something really wrong with the wiring or he's maybe a bit of a 'novice' and not up to the job. Can perhaps some learned members have a look at the photos and give your opinion?
I must admit I was a bit concerned when I saw the wires in the light appeared to be reversed. That light was fitted by the builders and hasn't been touched until now, neither has the switch - I was/am a bit concerned by the exposed conductor, but it's easily fixed.
What do you all think?
Is an extra light possible? Is this wiring safe?
(I did look in the wiring diagram section but the links didn't go anywhere)
