- Joined
- 27 Jan 2008
- Messages
- 29,369
- Reaction score
- 3,610
- Location
- Country
The question is if switch, or lamp or interaction between the two, and how to stop it? I see many reports of flickering with dimmer switches, but in my case the electronic switches are on/off with no neutral and recommended wattage over 5 watts. They are Energenie MiHome switches but it is unclear if it is switch or bulb.
I have 5 smart switches with no neutral, you can hear them click so assume must have a relay inside them, and with a single 10 watt BA22d bulb they work A1, also with 8 and 5 E14 (SES) bulbs not dimmable also work fine, the instructions say to use dimmable bulbs, I would assume this is so some current can flow through switch when off to work electronics, removing a bulb and replacing, or any other interruption of supply turns the switches off.
The three GU10 bulbs in my bedroom flickered, so swapped bulbs with those from kitchen, and in the main it has stopped the flicker, but every so often it can be noticed.
Wife's bedroom has been a real problem, 5 G9 2.4W bulbs in a chandelier, on fitting the smart switch they would not turn off, but would flash, bulbs all say dimmable, so load capacitor fitted, this allowed lights to turn off, however still a flicker, not all the time, it seemed what ever is done stops it, then it returns, then one bulb failed, since in lock down, a quartz tungsten bulb taken from another room, and fitted in the chandelier, all flicker stopped, and you can't tell which bulb is the odd one out.
So if it is load, then why no flicker with single 10W BA22d bulb? If switch then why do all bulbs stop flicker with extra load? It does seem to be connected to bulb size, the 5 watt E14 bulbs have no problem but there are 5 in smallest chandelier, with 3 x GU10 I would guess also 5 watt on the odd time there is a problem, but very rare, and with the 2.4 watt x 5 G9 bulbs there was a problem until one bulb changed for halogen, so some things point to switch and some things point to bulbs so seems likely an interaction between bulbs and switch, and neither is faulty as such.
But is there a cure? What I hope is people will add to this with their experience, and maybe we can actually work out why LED bulbs some times flicker with electronic switches?
