Pyronix euro 46
10 Feb 2019
Hi i set my alarm the other day and went to omit one of the zones it said on the screen it was done tried it and my alarm went off any suggestions
The omitting process is not clear with the Euro. If you press D and enter the menu there is an option to omit zones. However this only omits 24hr zones. To omit a normal zone start to set the system then press yes and select the zone you want omitting.
Ill try this
Quick one I had a mains electricity trip last nite but my alarm never went off is this normal or is there a setting not rite.
Mains fail alert is on a timer set to 40 mins as default, as for the zone you omitted are you sure they are all labelled up correctly
ok so after 40 min it will go off. Yer i sorted it out i found the front and back rooms were the wrong way around and now i can omit as normal now.
