    Dismiss Notice
Pyronix euro 46
Discussion in 'Alarms, CCTV & Telephones' started by Rustynut, 3 May 2020.
  1. Rustynut
    Rustynut
    10 Feb 2019
    79
    Thanks Received:
    3
    Country:
    Hi i set my alarm the other day and went to omit one of the zones it said on the screen it was done tried it and my alarm went off any suggestions
  2. Sponsored Links
  3. sparkymarka
    sparkymarka
    16 Feb 2011
    7,914
    Thanks Received:
    1,205
    Sheffield
    Country:
    Does the zone have the omit permission?
  4. Rustynut
    Rustynut
    10 Feb 2019
    79
    Thanks Received:
    3
    Country:
    Yes i will double check i am sure i done them all to when i programmed it
  5. Rustynut
    Rustynut
    10 Feb 2019
    79
    Thanks Received:
    3
    Country:
    Just checked and omitable yes
  6. Sponsored Links
  7. Gibbies
    Gibbies
    17 Nov 2019
    64
    Thanks Received:
    7
    Country:
    The omitting process is not clear with the Euro. If you press D and enter the menu there is an option to omit zones. However this only omits 24hr zones. To omit a normal zone start to set the system then press yes and select the zone you want omitting.
    • Thanks Thanks x 1
  8. Rustynut
    Rustynut
    10 Feb 2019
    79
    Thanks Received:
    3
    Country:
    Ill try this
  9. Gibbies
    Gibbies
    17 Nov 2019
    64
    Thanks Received:
    7
    Country:
    Obviously will only work if the zone attribute ‘omit’ is yes.
  10. Rustynut
    Rustynut
    10 Feb 2019
    79
    Thanks Received:
    3
    Country:
    it is set to that in the menu
Loading...
Share This Page
