Hi all new here,
I rent from housing society and have asked to do work on the property myself. They have sent me a form to complete. It's a non standard build and the wiring involved in set into the door frame. I am asking to remove the door and block up as it's never used.
My plan is to do stud work, plasterboard etc and run the existing light wiring into the stud work. So all I'll be doing is disconnecting to current light switch(s) and re-route. Before I put in my application I was wondering if I will need a sparky to issue a certificate and will this work full under UK Building Regulations.
I have attached a photo doorway, on the frame you'll see the light switch, same the other side door hallway light.
Many thanks
Dave
Many thanks
Dave
