Small under sink heater
18 Mar 2018
Can you get a little instance electric hot water heater that will go under a sink as apposed to over and pipe up to a tap on the sink? Thanks
I don't really want a stored one as can't get a pressure relief on expansion vessel or loop in.
Loads. The 3kw ones are perfect for handwashing in occasionally used spaces, the 10kw ones can run a usable shower. Beware of the 3 phase ones unless you have a 3 phase supply. Google is your friend here as is Ebay
Guess it all comes down to what you want it for and what you would be happy with in terms of how hot and how much of a flow of water you want
Dafi- been trying to remember that name all day. I've got 2 of the 3kw ones (one in the garage, one in the downstairs loo). You don't get a massive flow rate but does handwashing perfectly
