Honeywell controller to Hive controller
31 Jul 2008
Northamptonshire
Hi everyone
I'm going to install a hive acting heating system.
I have a system boiler (Glow worm 30sxi) + Maxiflo - edited thanks to Chris W with Honeywell controller and a wall thermostat
Does anyone know why there are three earth wires and should I connect them all to the earth hive?
I will wire the N and L the same and 3 and 4 the same but can anyone spot the wire to the thermostat I could leave disconnected in the Hive?
Any questions needed, fire away
you have the wrong Hive for a combi boiler, it might be able to be used depending on what boiler you have, if your boiler is low voltage switching then that Hive cant be used
Ah sorry my mistake I do have a single channel hive , this is the wiring diagram for it
Any help with the questions from my first post, I'd be very grateful?
Boiler is a Glowworm 30sxi
Isn’t a Glowworm sxi a system boiler? So what would control your hot water?
Yes it's a combi boiler I think, I should add I have a megaflow tank in the airing cupboard with two motorised valves and an immersion heater.
The immersion heater is always off.
That’s not a combi boiler. You have a system boiler with an unvented cylinder. The first wiring diagram shows the correct hive you need.
Ah thanks very much - I will exchange the hive - for when I do get the correct dual channel hive, any pointers on the wiring?
Edit: Exchange sorted on amazon
I think the wiring looks the same, so maybe leave the backplate in, and fit hive to that?
Yes get someone that knows what they are doing, you dont even know what system you have so how are you going to wire up new controls ?
mmm... that's not very helpful is it, there are countless threads here with someone like me asking for similar advice
Thanks both, I tried to fix the hive onto the existing backplate, but it doesn't really fit.
For clarity this id the wiring of the existing controller
Shall I just wire the hive up the same and put the wall thermostat on max? Or can I disconnect the thermostat wiring?
Thanks again for any help
