Sealing clay waste pipe connection in a manhole
28 May 2020
The photo below shows the chamber under a manhole at my house. There's a horizontal channel formed in concrete (perhaps there's a clay half pipe under it?) that is connected to a clay pipe leading to a toilet.
That connection appears to have been sealed with something like mortar or cement that has cracked leaving a small (maybe 1/4 inch across) gap between the clay pipe and the concrete. When there is water in the drain, I can see it running into this gap, and I'm worried not only about sewage regularly seeping into the soil under my patio, but also about a void forming.
The junction is very much accessible and I can easily scrape out the loose material and replace it with something. However, I've no idea what.
Apologies for the very basic question, but what should I be using use to fill this gap?
We use something called Milliput for that. I’d probably sink my grinder in to make sure it’s a clean and even gap.
Thanks for the replies.
It looks like Milliput is a sort of epoxy resin and I'm certain I have some of that kicking around. That certainly seems like an easy fix and the joint is so small I think it's going to be a lot easier to work with than cement so I'll give it a go.
I'll be sure to remove as much of the loose material as I can.
Thanks again!
To add from a safety point of view, not sure how deep the chamber is, but be mindful of Hydrogen Sulphide. It collects in sewers, and is highly poisonous, too high a concentration and it knocks your sense of smell out, making it even more dangerous.
Milliput is a 2 part epoxy putty, it's not a resin/glue.
Don't use a 2 part epoxy glue/resin as it won't hold if there's any debris etc.
Thanks. I did in fact mean putty - not sure why I called it resin. I really appreciate you picking up on that and warning me though - thanks.
Thanks - I appreciate the warning. I understand it's also flammable, so I'll toss a match in first just to clear any that's in there.
I'm joking :) This is fortunately quite a shallow chamber - I can easily reach the crack whilst keeping my head well outside. There are much deeper manholes further along the patio and drive where I wouldn't attempt a repair myself because I wouldn't have any confidence that I'd be safe doing so. It's a fair warning and good advice - thanks!
