Putting 240 volts into this power supply may have damaged it beyond repair
some led drivers
No, they all use 230V, the same as we do.Presumably the 120v version is for the continent ...
Could be fine. Just can't see if it has a minimum current.Can I not replace it with this? The led connection mechanism will just wire into the 24v terminals of this driver?
I am agnostic on the subject,
The total wattage of the 3 lights does not exceed 30W. I was asking about the 24 volt requirement and checking that the three lights in total don’t exceed this?1. The power supply/driver is for 30W. So that's how much power it will supply. If the 3 strips add up to more then you would have a problem (though you could choose a higher wattage part).
“Negative” should have read “Neutral”. Sorry.(Also live relates to ac and negative to dc - so the question is unclear)
The 24 volts would be applied to each of the strips in parallel, so each strip would be driven by 24V. So everything would be fine. It's similar to the sockets in your house all being in parallel so you see the same voltage at each socket.The total wattage of the 3 lights does not exceed 30W. I was asking about the 24 volt requirement and checking that the three lights in total don’t exceed this?
Also, can you please elaborate on #3. Why would there be any current flowing between these terminals when the switch is not on?
would be an issue if the voltage on the DC was higher than 24? Let’s say 75?
