sorted.
First part answered. Now interesting. As thread went on, the point of spurs on a ring being protected by only a maximum of 13A, even though the spur cable is rated 26A, came up.
Scenario.
Looks very legal to me now. Clearly electrically sound and safe for sure.
- A 32A ring, 2.5mm cable.
- Junction box in ring then 2.5mm to a garage or out-building.
- In garage/out-building a small CU.
- CU has a 20A MCB/fuse protecting the garage/out-building and the 26A rated spur cable.
- Spur cable protected as it is rated at 26A - all safe.
- After the 20A mcb, which protects the whole garage/out-building, a couple of 16A radials for sockets, say one for inside and for the outside for garden socket use.
- Another mcb at 3A for LED lighting.
- Circuits off garage/out-building split, so divide & rule.
Is it longer than 3M?
Reg 433.2.2
So legal, as BS is recommendations.Legal? There are no laws defining or requiring any of the above.
Hypothetical.
I struggle big time to work out what you are actually trying to achieve with these nonsensical questions. To add insult you then argue with people giving perfectly adequate answers. So why have you come up with this stupid scenario after so much excellent advice?sorted.
Scenario.
Oh I've read it OK, all the way through and as has become the custom your questioning is becoming more confusing.Mr Sunray, it is best you read the first post first and work your way through.
Different to what EFLImpudence wrote.Anyway just in case you are silly enough to start installing the above, the maximum OCD for a spur off a 'standard' RFC is 13A fuse or 16A MCB.
If you cannot understand the first post you have comprehension problems. It seems it is common here.Oh I've read it OK, all the way through and as has become the custom your questioning is becoming more confusing.
I'm still trying to work out if these are schoolboy questions, curiosity, serious learning, wind-up.
... Of course it cannot have more than one socket off spur....
Indeed I understand the OP perfectly and, as has become your trademark, you have turned the thread into gobbletygook.If you cannot understand the first post you have comprehension problems. It seems it is common here.
Not this loony - more noise. He follows me around the forums.However, since you have now confessed that you intend to hang a garage CU off it, with lights and sockets, you must protect your spur with a 13A FCU or similar.
I was a simple question. You even understood it, you wrote so. Then noise enters wanting know my shoe size, not understanding simple questions, or other irrelevant tripe coming in like the recent insertion.Indeed I understand the OP perfectly and, as has become your trademark, you have turned the thread into gobbletygook.
Let us into the reason for your unorthadox questions.
