I am looking to widen the opening that my front door currently sits within. I get the logic of how this is done but i have only ever seen examples with a standard lintel being removed. I guess it is similar but is there anything that needs to be done differently when replacing a cast in-situ lintel. How are they then best removed?
The SE has calculated that the total load on lintel will be 7.9kN and has specified;
I am planning on using 2nr prestressed lintels like these "Link" side by side
The opening is being widened to circa 1400mm so this will give 150+mm bearing on either side. The data sheets say they are good for 31.87kN so overkill.
Images above show what i am looking at. How is the best way to go about it.
Joists run parallel to the wall in question so no timbers bearing on that wall.
