Are there any best practice on where the the radiator should be positioned between the floor and the top of the window sill?
How does that relate to a window sill ?Bottom of radiator about 25mm above the skirting board.
Isnt the ops question ...where should the rad sit in relation to the window sill ?
As skirting sizes range from 70 mm to 350 mm
Based on your very helpful advice, I set this out earlier today.
I haven't soldered yet. Are you suggesting that I tighten the rad valve end before soldering?Oh! if its not too late I wouldn't solder with the valves in place, I keep some old ones to keep pipes in line while heating.
I Just wouldnt solder with new valves on the pipework as in your picture , excesive heat may damage them.I haven't soldered yet. Are you suggesting that I tighten the rad valve end before soldering?
