Hello,
I am currently in the process of making a trapezoid shaped shed at the side of my house, its roughly 6m in length and 1.2m at smallest end and 2.3m at the bigger end. I have almost finished digging 25cm below ground, as I am going for a thicker slab and hardcore base, due to the ground below appearing to be 100% thick clay.
After researching it looks like a DPM might be a good idea but have read that it should be installed ground level and not sub level due to water ingress into the slab. So am thinking would it be acceptable to fold the DPM up the side of slab till it reaches ground level and use some kind of sealant/glue or fixing to keep it tight against the slab?... Or not... If not any other ideas on installing a DPM sub level?
Thanks,
Antony
Thanks,
Antony
