- Joined
- 15 Apr 2018
- Messages
- 300
- Reaction score
- 3
- Country
Hi all
I need to move the location of my loft room radiator ( we are changing it and the valves at the same time)
we have a combi boiler system
The rad it the top of the CH system, at the moment it if fed via speedfit pipes.
these are going to be re routed in the loft storage area and will be extended to a different part of the roof and then connected to the rad via copper pipe from under the floor.
I have read about removing a a rad for decorating and it says to shut the valves off to stop the flow, then remove the valve to drain the rad.
So in theory i could do that and put speedfit end stops to stop the flow and then do all the pipe work and at the very end remove the endstop and join the two pipes together (if that makes sense) but that seems a recipe for disaster and a wet loft.
so then I thought could i just partially drain the system? take enoughwater from the drain point in the basement ( 4 storey house) so that the 1 rad in the loft (and the pipes) have no water in them.
could i then do the end stops on the pipes, move the pipes and fit the new rad with no spurting water?
Finally if i did this and it took more than a day would i still be able to use the boiler for hot water if it took longer than expected?
Many thanks in advance
