Hi All
My neighbour is currently ripping out their drive and will be extending it to cover the whole of their front of the house.
They will also be building a wall around the drive which is fine.
The issue is they want to join one of the walls to my wall which is on my side of the boundary.
I've attached a crude drawing to explain, the red bit is my wall at the back then as my house is elevated the garden is above the wall which then has a fence on top of it.
The grass bit spans both houses at the front and currently there's a little non panelled fence about 2ft which divides the grass bit indicated by the brown line.
The little sticking out bit is the vent for my boiler.
I think if they build this wall then I won't have any access to the vent if needed or to that side of the house in case any pointing or maintenance needs doing.
When the work started I did say I'm fine if you want the wall to start at the front and go up to my garage door/first manhole cover but not to block access to that side of my house which looks to have been ignored and they've cracked on.
Can they join the wall onto my wall fully and then bring the wall to the end of the drive where the two meet?
