Why can't i find the above on screwfix etc.
My understanding was that i can't just connect a flexi hose with a 1/2" female nut with rubber seal straight onto a compression fitting because the sharp end of the compression fitting will cut through the rubber seal.
In which case i'd have thought that a service/iso valve with a 1/2" flat face to connect onto a flexi hose would be readily available.
What's the normal way of connecting a 1/2" female flexi to a 15mm pipe?
