- Joined
- 7 Jan 2007
- Messages
- 8,816
- Reaction score
- 1,229
- Country
quick update...
I actually found the corefix screws really hard to work with. I drilled 10mm holes with the correct masonry bit but in 4 out of 5 attempts, the rawl plug wouldnt bite and the screws ended up spinning freely. I can accept one attempt going wrong but not four. I'm at a loss as to why it's not biting into the block work?![]()
Use the method I've suggested it works ! No messing about just make sure you use brown plugs , hammer them well in using the screw....then fit another plug in the same hole ( sometimes I've even used three plugs ).......don't use your drill on hammer when drilling in to the blocks it will make the holes too big !
