- Joined
- 21 Sep 2020
- Messages
- 13
- Reaction score
- 0
- Country
Hi
Newbie to the forum! Hoping you great people can help me out with a few queries on Texecom alarm systems.
Planning to self install the following:
House
I've done hours of research using information I can find, but would be grateful of any comments on the following:
Thank you
Skylar
House
- Texecom Premier Elite control panel
- Texecom Connect SmartCom Ethernet/Wifi Communicator
- Texecom Premier Elite SMK Keypad (wired)
- Texecom Premier Elite Remote Zone Expanders (wired or wireless zones, depending on chosen control panel)
- 8 x PIR Dual Tech sensors (wired)
- 2 x magnetic contact sensors (wired, unless cable routing issues force my use of wireless)
- 3 x optical smoke sensors or sensor/alarms (wired)
- 1 x smoke/heat alarm for kitchen (wired)
- 2 x panic buttons (wired)
- 2 x Texecom Odyssey X sounders (wired)
- Texecom Ricochet Premier Elite Smart Key to deactivate garage alarm area and somehow trigger garage door opener.
- Texecom Premier Elite wireless Keypad (if needed?)
- 1 x PIR sensor (wireless)
- 1 x magnetic contact sensor (wireless)
- 1 x smoke/heat alarm (wireless)
- 1 x dummy sounder
- Is the Elite 64W control panel 'better' (newer, better processor or main board for example) than the Elite 48? Any other differences, apart from the 64-W having polymer case, onboard wireless and higher maximum zone limit?
- Would you buy the Elite 48 + Elite 8XP Expander + Ricochet 8XP-W Expander or the Elite 64-W + two Elite 8XP Expanders, giving more wired and wireless zones for future expansion?
- Would you use the smoke/heat alarms available for the alarm panels, as some advice seems to suggest a separate fire detector/alarm system is safer and can still be linked to invoke the intruder alarm sounders?
Thank you
Skylar
