Hudson Reed Genie shower tower (AS361), dripping help.
23 Sep 2020
Inset square fixed head continues to drip. I disconnect water pipe to shower head and switch off the power, but the water still coming from the pipe.
I enclosed the video and the photo of the back of tower ,can anyone help me which part i need to order to fix the problem, please?
I contact Hudson Reed customer service ,they can't help at all because the unit is DISCONTINUED.
So far what i try (pic 3) i swap the head unit and washer to hand shower unit, but no luck, still keep water drip on head unit.
Welcome to DIYN!
Didn't you close off the water supply to the pipe?
Dud you find a solution to this problem as mine doing the same so appreciate advice if you solved it. Violet
