Indeed - and, as so often discussed, that was always ridiculous (and, were it not for the almost inevitable 'incidental earthing' of internal pipework, could even have been dangerous).Yes, but then up until and including the BYB 544.1.2 said "insulating section" and required the Main Bond to be on the customers side of that insulating section.
... but not if the downstream end of the 'insulating section' is above ground or, even if within the property, so close to the entry point that it was 'not practicable' (nor, in common sense terms, necessary) to bond it upstream of that insulated part.The gas people presumably want it but if there is still a metal gas pipe entering the premises then that will still require a Main Bond ....
Sadly, that will probably remain so in many cases. As above, I would be concerned about this were it not for the fact that the internal pipework will almost always be earthed, even if not main bonded - so unnecessary/inappropriate bonding probably very rarely creates an additional hazard.... - but the electricians will probably not realise and bond in the wrong place as they always have.
