It's funny how different peoples memories work.I think gas was used as a scapegoat here. There were other serious problems:
- it was not adequate for expected wind loading, since the wind speeds which the regulations required to be considered were much too low for a tall building—in a high wind, an upper wall panel could be sucked out, leading to collapse similar to the actual collapse
- it was not adequate in a fire, a significant fire could lead to bowing of the structure, followed by collapse as above.[7]
There may very well have been other problems but let's look at the facts as I remember them:
1) A gas leak [of some type] occurred in an upper floor about 3/4 of the way up the block.
2) An explosion occurred when the female tenant lit the cooker.
3) The outside walls of the kitchen and lounge disappeared.
4) Everything supported by the missing walls fell.
5) The weight of the debris falling onto the lounges below made them collapse.
6) The builders were found to have not installed the precast sections correctly, using cardboard instead of the proper products.
7) The building was repaired to the proper spec and repopulated.
8) Public pressure got the building dismantled 15 to 20 years later [note dismantled and not demolished] for precise examination.
9) As a result of 8 above other buildings of the same design were in use for many more years.
10) There were many many buildings built to this exact design and I believe this was the only one to suffer in this way.
11) When demolishing buildings to this same design they do not collapse in the same way without the use of a massive explosion comparable to that of the gas incident [tested and accepted].
All of the above is from memory, I would say I was about 11 or 12 at the time [1966-68] and I'm pretty sure it was about 1985-87 when dismantled.
If any details of 35 to 50 years back are incorrect I offer my humble apologies in advance.
As I understand it the cooker was repaired and the lady made a good recovery but a handful [very few] lost their lives as the tower was quite new and not fully let.
Lastly I don't believe anyone apart from Winston has any doubt about a gas explosion being the cause of the incident.
