D
Deleted member 267285
Still no joy. Is there anything else?
Try what Terry has suggested. If upstairs works, and the piping behind that radiator looks ok, as in flow and return then it’ll be something else.
Doesn't matter ,except the water coming out after a while will be very hot.Thanks
I've gad the central heating on. So i will switch it off. Do i need to wait for it water to cool though?
Didn't have a second person.Fit the actuator head onto the Trv and turn it off. Leave lockshield fully open . Have a large container handy and open the air bleed valve ,let water run into container for 5 minutes ,have a second person topping up pressure. See if this shifts any air trapped in the return pipework.
The water was never hot.Doesn't matter ,except the water coming out after a while will be very hot.
The drain cock is on the TRV / flow Chris . Trying to establish if return is full of air , (and if the lockshield is allowing water to pass ,which it seems to do)What about connecting a hose onto the drain off, leaving this open, and topping up pressure? Might work @terryplumb?
The pressure dropped to a trickleDid the pressure of water coming from the bleed valve drop to a trickle ? You really need to keep the pressure up whilst doing this ,even if you close the bleed valve ,go re pressure ,go back to bleed etc etc.
And this time do it for ten minutes fully.
The radiator is full of cold water ,so until all of it is expelled ,together with any cold water in the return pipe ,only then will any hot come through. Hence the need for pressure top up whilst doing this trial ,and long enough time to clear any air present.The pressure dropped to a trickle
Okay, i will give this a shot
But isn't it worrying that i have a bucket full of water from the bleed valve and none of it was warm?
I gave it a good go.The radiator is full of cold water ,so until all of it is expelled ,together with any cold water in the return pipe ,only then will any hot come through. Hence the need for pressure top up whilst doing this trial ,and long enough time to clear any air present.
My towel rad doesn't have a TRV.Ok ,if you didn't get a lot of spluttering and air coming through ,that pretty much rules out air lock.
Don't bother trying again ,but do this instead.... Open the TRV and close the lockshield ,and perform the same testing ,bleeding / topping pressure for ten minutes. This will confirm water is flowing into the rad thru the TRV , and clear any air from the flow. After doing this ,open both rad valves but turn OFF all other rads by their TRV ,switch on central heating and leave running for 15 mins.
System has been bled/topped. Switched off other trv'sOk ,if you didn't get a lot of spluttering and air coming through ,that pretty much rules out air lock.
