How common is RCD protection?
Is there RCD protection
  • None
    Votes: 2 8.3%
  • Only outside sockets
    Votes: 2 8.3%
  • Split CU some circuits
    Votes: 5 20.8%
  • All circuits 2 RCD's
    Votes: 6 25.0%
  • All circuits more than 2 RCD/RCBO's
    Votes: 9 37.5%
  • Old RCD 100 mA
    Votes: 1 4.2%
  • Very old ELCB-v
    Votes: 0 0.0%
  • Total voters
    24
I think some electricians still consider a first floor flat on PME suipply does not require RCD protection (as far as an EICR goes)
My house has the original "fusebox" from when it was built in 1959
There is a card with fuse wire on hanging next to it -left by the previous house owner
and yes I know it needs updating
I don't think that I have ever heard that one - can you perhaps give me some insight into their reasoning/thinking?
Possibly assuming no sockets here can be used for outdoor use, perhaps?
Maybe, but we are years past the day when it was felt that only such sockets 'needed' RCD protection.
What often seems to get overlooked is that, contrary to common misconceptions, the main potential advantage of RCDs is not that they will trip if someone receives an electric shock but, rather, that they will often trip in response to an L-E fault which will not (or not for a long time) trip an OPD long before a person gets a chance to suffer a shock - and that scenario is at least as likely (probably much more likely) indoors as outdoors.
Don't think I can vote. No RCDs except standalone board with RCD for shower only.
I would say that more-or-less counts aa "Non"!
One thing this poll has indicated is how important it is to spend a lot of time carefully thinking about the response options to bbe offered in a poll such as this.
No, it's not non - can't say it's non.
I'll pretend and settle for non except for outside sockets
No, it's not non - can't say it's non. ... I'll pretend and settle for non except for outside sockets
I don't really understand. I thought you said that the only RCD was for a shower, didn't you? If so, then why "non except for outside sockets", if the outdoor sockets don't have RCD protection (i.e. are not an "except")?
Because there's no option for non except shower. Don't want to put just non, because there is one circuit that is RCD protected.
Non except outside sockets = only outside sockets. Doesn't it??
Indeed - but, unless I've misunderstood you (to be saying that your only RCD was for a shower) then "only outside sockets" is totally wrong for your installation, isn't it?
Yes but to put just non (or does he mean none?) is totally wrong too, as there IS an RCD, on an important circuit as a shower.
My argument was that 'outside sockets only' implied just one RCD too - BUT on reflection, this could consist of several RCDs, either at the board, or, as I just realised, built into the actual outside sockets themselves.
Which I didn't consider earlier.
