- Joined
- 11 Jan 2004
- Messages
- 42,722
- Reaction score
- 2,630
- Country
I plan to lay a new 22mm chip floor.
I shall put 100mm Kingspan or similar under the floor first.
Is it:
1. Better to use ply?
2. If using chip, would you PVA the tongue and groove?
3. Would you bead flexible adhesive on the joist-tops to minimise squeaks?
4. Would you foil tape over the joists to give continuity to the vapour barrier?
5. Or would you lay a sheet vapour barrier under the chip?
Thanks for your suggestions.
Is it:
